Hey so my car is currently acting up, it started off with just the abs, power steering, and vsc lights on then i got to the gym and did a 5 minute drive and the check engine and brake light came on as well. I decided to scan it then my cars rpms went up to 1.5k and stayed there. I proceeded to try and drive home but car went in limp mode, so i turned it off and back on and drove home but it ended up going into limp mode again. the codes i got after scanning it the latest time is
p2127
p2138
p0651
p2422
p1454
battery was at 78% after i did that 5 minute drive as well but i went to auto zone and they said it was good, i took it to advanced and they said it needed to be replaced so i used my own and the voltage was normal? but cca were at 580 instead of 500.
p2127
p2138
p0651
p2422
p1454
Feb 8, 2025 at 7:51 AM
