Check engine light on with codes
1999 ACURA CL
259,000 MILES
SANDI1219
Check engine light just came on with Codes P0430, P0706, & P0401.
Prior owner said had Tranny rebuilt 2 years ago. Car runs great. I noticed that car has a slight jump when shifting. No other problems as of yet.
How do I know which code is the problem or if it could be all 3?
Oct 20, 2013 at 11:42 AM
HMAC300
  • 48,601 POSTS
code 430 is a converter/O2 sensor problem the 706 is a tranny problem401 is the eger problem so it could be partially clogged or egr valve not working. the tranny problem a atrans guy should look at it.
Oct 20, 2013 at 3:15 PM
HONDATECH1983
  • 109 POSTS
I'm not seeing a p0430 as a relevant dtc for this model. P0401 is most likely the egr ports clogged with carbon. The p0706 is for the transmission range switch. Make sure they didn't leave that connector loose.
Nov 20, 2013 at 11:55 AM
