I bought this car form the original owner (sister in law) The car is stock down to the broken 6-disc stereo. They have had no issues with this car except the check engine light being on. Their mechanic said that it needed the EGR cleaned and the oil pan gasket needs to be replaced. On the way back home, it stopped running and after some trouble shooting, I discovered it was the fuel pump, so I replaced that. I disconnected the battery when I did that. My code reader pulls no codes, but that check engine light is still on. She that the car "surged" at idle, but I have not noticed that, nor any other issues.
Shouldn't there be a code or two if something is up with the EGR? I am prepared to clean the EGR ports behind the throttle body, but would like to have some input before doing something that may not be necessary, or throwing money at a check engine light with out having a good idea what it is on for.
Jun 2, 2016 at 2:33 PM
