When I try to start the car I sometimes get a strong odor of gas. It does not always start the first time. I have to pump the gas. It has a new battery.The check engine light is on and flashes when I try to accelerate. The rpm's increase also until the car stabilizes then the rpm's go back down and the engine light stops flashing. When trying to accelerate sometimes there is hesitation and jerking as if there is water in the gas but worse. Had Autozone check it and they told me it is probably the canister purge valve, or spark plugs, wires, coil or distributor cap?
Oct 9, 2017 at 3:36 PM
