Check engine light not on at a start
2002 KIA SEDONA
165,163 MILES • 6 CYL • TURBO • AUTOMATIC
EFISIWORLD
My check engine light will not up when I turn on the ignition but every other light does.
Jan 10, 2018 at 3:25 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Check the "meter" fuse in the junction block located behind left side of dash.
Jan 10, 2018 at 6:52 AM
EFISIWORLD
What should I do at the meta fuse box because all fuses are okay?
Jan 11, 2018 at 3:13 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
It is a single fuse labeled "meter" in the junction block located behind left side of dash that you should check and make sure it is not blown and if you have a voltmeter or at least a twelve volt test light, make sure this single "meter" fuse has voltage on both sides of it.
Jan 11, 2018 at 6:04 AM
