check engine light is on and falters after engine runs a little bit
1998 DODGE TRUCK
150,000 MILES
STEVEMERKLE
It ran great then changed front brake lines now having trouble. Couldn't find any vacuum leaks, took it autozone they put the scanner on it and came up with two oxy sensor codes PO132 and PO138. I was told the odds of both of them going bad at the same time is rare especially after the repair. How can I tell if they are really bad and what else can cause these codes? The engine idles fine starts fine but when it gets warm and up around 50mph it sputters falters and loses power but it doesnt stall.
Oct 16, 2013 at 11:13 AM
WRENCHTECH
  • 20,761 POSTS
What engine does this thing have?
Oct 16, 2013 at 12:00 PM
STEVEMERKLE
5.9 L
Oct 16, 2013 at 3:29 PM
WRENCHTECH
  • 20,761 POSTS
These are both high voltage codes so someone is going to need a high grade scan tool and they are going to have to look at a lot of things to determine where that voltage is coming from. I'm afraid about all you could do yourself would be to go back over your work carefully and look for pinched or damaged wires. Make sure there is nothing causing the engine to run extremely rich because that's basically what a high voltage report is if it's accurate.
Oct 16, 2013 at 3:45 PM
