I recently installed an aftermarket radio into my vehicle listed above (SE model) using a plug-and-play harness. Shortly after installing, the engine light came on. The speedometer and tachometer are working perfectly fine, and the car seems to be running fine as well, but my cruise control won't work or even turn on. The only thing I could think of was that something must've shorted when I installed the radio. I took it to a local car shop that I trust and after spending $400.00, they could not figure out what is causing the engine light to come on. The error code is pretty consistent -- P0500. I did buy the vehicle speed sensor part online and gave it to them. They said they replaced the old one and the light still comes on. They said they didn't see any physical damage to the wires either. The last thing they also said, when they removed the sensor, the engine light turned off, but then the vehicle won't shift properly. When they put the sensor back on, obviously, the engine light came back on but the car drives and shifts normally. They tried to take apart the center console to check for the computer module but they said they didn't find one in my car, so they just ended the search from there as my bill was climbing with no solution in sight.
I am at a loss. I don't want to take my car to the Toyota dealer and have them tell me the same thing or even send me a higher bill for parts that I don't need. I was wondering if you guys can share anything that you might suggest I should do. If I go have another mechanic take a look at it, what should I tell them to look or check for that the other mechanic hasn't done?
Thank you in advance.
Jul 24, 2021 at 3:30 PM
