Check engine light is on code P1447 Diagnostic Module Tank Leakage Pump.
Had it at the mechanic shop and they replaced the valve cover and seal since it was leaking. I told them about the P1447 code, and they told me that could be one of the reasons. They showed me and I saw the leak, so I am not upset for them doing the work, but I questioned if that is the cause for the check engine light. Next day after I got the car back, the light is back on and the same P1447 code is the cause. Was there really a chance that the leaking valve cover could cause the code?
Sep 6, 2022 at 9:22 AM
