Check engine light does not turn on?
1999 DODGE DAKOTA
120,987 MILES • 5.4L • V8 • 2WD • AUTOMATIC
TOMMY L SHERIDAN JR.
Went to smog it everything passed but my check engine light doesn't come on.
May 1, 2021 at 12:55 PM
Chances are the bulb is bad or loose. To access the bulb, you need to remove the cluster and take it apart. If you look at the attachments below, they explain specifically how it's done.
See pics below.
May 2, 2021 at 6:54 PM
VIOLETLILA
  • 4 POSTS
this is where I bought my bulb https://parts.allmoparparts.com/search?search_str=bulb for my Dodge and other OEM parts.
May 5, 2021 at 6:18 PM
Thanks for the input. It's appreciated and will likely help others.
Take care and come back anytime.
May 5, 2021 at 7:23 PM
