I had a new compressor installed. After the install, the check engine light came on. Then i ran the scanner and the following codes displayed. I don't know if I clear some of the codes, the remaining ones will clear. they are: P2600 (the voltage supply of circuit 87 has under voltage), P240C (the selector level position sent from control unit n1 5/5), P240C, B1062, and P2005-002 B11/4 coolant temperature sensor, short circuit to positive or open circuit (po117). Can not move the stick shift from park to reverse easily, B1062 the voltage supply of the sensors M1 2b1 and M1 2b2 has short circuit or Open circuit, M4/3 Engine/AC electric suction fan.
Sep 20, 2021 at 3:57 PM
