Replaced engine, car runs great but have the check engine light on. I took it to a mechanic and scanner shows P0700 code. Replaced shift sensor, TCM and battery but still shows same codes. Now after all that when you shift from park to reverse if you do it just right it gets stuck in park but the dash says you are in reverse then flashes once and then turns to a park/reverse with a slash through it. Same from drive to third gear and back. It spent two weeks at a mechanic and it just seems to get worse. Other than that the car shifts and runs great. Can anyone steer me in the right direction?
Aug 23, 2018 at 5:09 PM
