I have spent about five hours trying to turn the check engine light off. Have done the "diagnostic fuse" procedure. Taken the battery cable off, touched negative to positive. And spent literally hours trying to find the "secret switch" in the ECU area under the dash (cannot find it). Have also looked for any issues causing a fault: vacuum hoses, had ECU re-manufactured and verified, cleaned the EGR valve, cleaned the fuel injector, new O2 sensor on the exhaust manifold. new chassis located fuel filter.
Help!
Help!
Sep 28, 2017 at 9:59 AM
