Check engine light turn
2015 KIA SOUL
20,000 MILES
KINGDARNIKIN
I put in bad gas and the check engine light came on 5,000 miles.
Sep 13, 2019 at 12:09 PM
Welcome to 2CarPros.
I'm not sure what you mean. I understand that bad gas can cause a misfire resulting in the check engine light coming on, but you have me confused with the 5000 miles. Please explain.
Also, if the check engine light is staying on, you should have the computer scanned to identify diagnostic trouble codes. That could point us to a specific cylinder causing a problem. Often times, a parts store will scan the computer for free or lend or rent you a scanner. Here is a quick video showing how one is used:
https://youtu.be/YV3TRZwer8k
Let me know exactly what the vehicle is doing, if you had it scanned, and what was wrong with the fuel you purchased.
Sep 14, 2019 at 7:47 PM
KINGDARNIKIN
It's fine now. i siphoned the bad gas out and put new gas in and after that about 6 hours or less the check engine light turned off and runs fine.
Sep 14, 2019 at 9:29 PM
Welcome back:
Great! It must have had the old fuel still in the lines.
Take care and let us know if you have questions in the future.
Sep 14, 2019 at 10:42 PM
