check engine code P0741 and P0700?
2007 CHEVROLET SILVERADO
201,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
MJULIAN
I am pulling these two codes P0700 and the P0741 Torque Converter clutch circuit performance or stuck off.
the truck shifts like a dream - I am wondering if the problem could be a sensor?
Jan 12, 2026 at 10:51 AM
These trucks had an issue after a few mile like you have as the TCC control solenoid going out and needing to be replaced. This will not effect the transmission shifting.
P0700 - Transmission Control System Request (this is a flag, not a failure)
P0741 - Torque Converter Clutch (TCC) circuit performance / stuck OFF
When you remove the transmission pan it will be the solenoid that has the blk/tan wire going to it. Replace it and then clear the codes, that should fix the problem.
Jan 13, 2026 at 5:38 PM
MJULIAN
Thank you
Jan 14, 2026 at 5:24 AM
You are welcome.
Jan 14, 2026 at 7:38 AM
