Check Engine Code P0456?
2013 JEEP GRAND CHEROKEE
87,000 MILES • V6 • 2WD • AUTOMATIC
SHELBYP
Check engine light came on, code given was p0456. The gas cap seemed a little loose I replaced it. How long does it take for the light to go off if that was the problem?
Jul 4, 2023 at 12:32 PM
It should go off after a few miles. Is the light still on?
Since this is considered a small leak, what I suggest is to have the EVAP system smoke tested. A small leak is extremely difficult to find just by visual inspection. When smoke tested, smoke is injected into the EVAP system at a very low pressure. If there is a leak, the smoke will come out at that point.
Let me know if you have questions or if I can help in any way.
Jul 4, 2023 at 11:02 PM
