check engine and repair airbag lights on
2004 CHEVROLET SILVERADO
160,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
BAMAFAN77
After changing my alternator and battery,my check engine light and airbag light stays on and the headlights,dash lights flicker,now my truck is idling rough and the whole truck will shake,it doesn't do all the time,does it hot or cold,while driving it still runs great and hasn't lose power.the truck is a 2004 ext cab chevy silverado z71 with the 5.3 engine and a whipple supercharger,I also just changed plugs and wires,what could be causing the problems,thanks
Jan 23, 2016 at 2:25 AM
WRENCHTECH
  • 20,761 POSTS
Your first step is to have the codes read in both the PCM and the Air Bag module and they should get you pointed in the right direction.
Jan 23, 2016 at 4:48 AM
BAMAFAN77
Thanks,I'm going to have it checked in just a little while,respond back after its checked
Jan 23, 2016 at 5:29 AM
