Hello - I'm wondering if you can suggest some troubleshooting steps for my problem. Had some odd electrical things happening (dash lights flickering, infotainment system rebooting, car also stalling at a stop). I went to my local auto parts store, and they tested the battery and the alternator, both tested bad. Both were pretty old, so I wasn't surprised. Replaced both. First two days everything was fine. Third day it almost stalled at a stop, then at subsequent stops though out the day it almost stalled, and the Charging System Malfunction light would come on for a split second then go off. During that split second the power steering would cut out then come back, and the infotainment system would reboot. I went back to the auto parts store and had the battery and alternator tested again, both tested as good. Just to make sure, I did the tests at home with my multimeter. Tested out as good. I also made sure all connections are tight and don't have corrosion.
What do you suggest for the next steps?
Thanks for your help - Jeff
Jun 11, 2025 at 8:52 PM
