Charging system
2006 CHRYSLER SEBRING
147,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
AMY ANTHONY
My car will not start at all there is nothing all lights come on. And the lights do not dim. Hit the starter now i am only getting a little click that is it.
Jan 19, 2018 at 9:19 PM
HARRY P
  • 2,292 POSTS
I would suspect that the starter or starter relay is bad. I would start with replacing the relay and then, if the relay did not solve the problem, I would remove the starter and have it tested. AutoZone, Advance Auto, O'reilly, and Pepboys all test starters for free.
The relay is in the power distribution center (PDC), which is under the hood, behind the battery. The layout of the PDC is attached below. The relay should be available at the parts stores.
If the relay did not solve the problem, then have the starter tested. The process for removing and reinstalling is in the images below. It is fairly simple, actually.
Let us know what you find and we will go from there.
Jan 20, 2018 at 3:29 AM
AMY ANTHONY
Okay, I will check that today.
Jan 20, 2018 at 6:25 AM
