Good morning.
Not hard at all. remove the coils, one bolt holding each and then remove the plugs.
1. Remove the ignition coil(s). Refer to ignition coil replacement (See: Ignition coil removal and replacement).
Note: Make sure that any water and/or debris is blown out of the spark plug holes prior to removing the spark plugs.
2. Remove the spark plugs using a 5/8 inch spark plug socket.
Mar 20, 2018 at 5:08 AM
