Voltage when car starts goes to 15v, idling for 5 minus goes down to 13.2-13.9, under load regains 14.6.
Before used to always stay between 14.6-15.4v.
I have a car audio system, 400a alternator, and 2 jy hp40 lifepo4 lithium batts. Voltage has always been somewhat of a problem to my 4000-watt amp going into protect mode before it hits lower than 13.8. I had the same amp at .25 ohm on a 250-amp alt with 2 110ah agm batteries in a 05 chevy impala, voltage stayed at 14.8 and maximum drop full power dropped to 14.2.
This vehicle has 16 grounds in total mixed with 1/0 and 4/0 cables, and duel runs of power of 1/0 from alt stud to back, and 4 power runs and grounds linking each battery using bus bars. I have triple checked all connections, made sure voltage reads the same from front to back. No resistance in the grounds.
Today my car decided to stay at 13.2v after a heavy load from my new 12k watt amp. It stayed at 13.2 until I restarted the car. It regained to 15v, but slowly fell back down to 13.2 even with driving. After some time and driving back to work, the voltage drops down to 13.9 now after settling from 15v. Before, alternator held 14.6 to 15.4v at all times and regained.
The issue also is when taking a heavy voltage drop that much, when it does regain, it regains from 13.2 to 13.7 very slow, then from 13.7 to 14.6 or setpoint in the PCM regulation jumps instantly. It's just that little drag until the alternator seems like it wakes up.
I was looking into mechman 400a alt now, the one I currently have is from gpcaraudio.com. I am using a standard vehicle harness to plug into it. Mechman is a bit different, they turn the 2 pin into a 4 pin, and they say to put the factory harness with the box they give to trick the battery light, and 2 wires, 1 that loops back to positive stud, and another that has to be ran with 12v ignition. Will that type of alternator eliminate the PCM regulation? Because that's what I think I'm trying to do, as lithium always has to be above 13.8v. Can't have it going into sulafacion mode and causing a load on them as it's not safe.
Dec 17, 2023 at 2:17 PM
