Charging issue
2005 AUDI A4
127,000 MILES • 4 CYL • TURBO • AUTOMATIC
DIVIDES
  • 903 POSTS
Battery light would come on sometimes but only after car has been driven for a while, and then if you turn it off and back on it would need jump. Replaced alternator and the volts at battery are 13-13.40 while idling and as soon as i hit the pedal to rev it up it drops to under 12. At the alternator the output is 14.47.
May 20, 2021 at 2:27 PM
So the voltage at the battery is 14.47 when running? if so the battery might be bad. To be sure lets run down this guide to confirm the issue:
May 21, 2021 at 10:54 AM
DIVIDES
  • 903 POSTS
The voltage at alternator is 14.4 at the battery its 13.5, but when i hit the gas pedal while parked it drops to 11.90-12.90 then when i let off it goes back to 13.4 gradually.
May 21, 2021 at 11:18 AM
DIVIDES
  • 903 POSTS
And while parked if i turn the A/C on after its warm it goes from 12.20 fluctuates like crazy until it reaches 13.3.
May 21, 2021 at 11:22 AM
DIVIDES
  • 903 POSTS
Battery replaced twice with new ones.
May 21, 2021 at 11:25 AM
Did it do this with the old alternator too?
May 21, 2021 at 11:37 AM
DIVIDES
  • 903 POSTS
Yes.
May 21, 2021 at 11:41 AM
DIVIDES
  • 903 POSTS
Now says 13.8 but A/C hot, the ambient temperature reading -38. where is the sensor for that?
May 21, 2021 at 2:32 PM
The alternator output is controlled by the PCM but lets check the connections to the alternator to confirm the PCM is going bad. This guide can help I have included the alternator wiring diagrams below so you can see how the system works:
we need to keep this thread on the charging issue. Please post your new question here, you must be logged in.
May 23, 2021 at 10:13 AM
DIVIDES
  • 903 POSTS
Never mind i sold it.
May 23, 2021 at 10:46 AM
