charging A/C with new compressor, do i drain the PAG oil prior to installing?
2005 CHEVROLET TAHOE
230,000 MILES
KMJTURNER
If not, after i vacuum the system for 30 minutes do i need to add recommended PAG oil or does this oil remain in the system and i do not need to replenish?
should i charge the system via liquid initial then switch to vapor when i get the truck running and compressor on?
The video looks like he is charging with liquid only.
Thank you for your advice.
Jul 20, 2023 at 9:51 AM
Most of the time a new compressor will come with the oil needed already installed so you don't need to add more. You can charge with the gas instead of liquid, no problem. Please let us know if you need anything else to get the problem fixed.
Jul 22, 2023 at 10:50 AM
KMJTURNER
Thank you, I will proceed with liquid charging and advise if more info is needed.
Jul 24, 2023 at 8:51 AM
Please watch this video, if you are uncomfortable just charge it with the gas. Please watch this video.
https://youtu.be/4EqdrBVb0sY
Please let us know how it goes.
Jul 25, 2023 at 6:34 PM
KMJTURNER
Thank you, this is the video i was going to follow. will update once all is complete.
Jul 26, 2023 at 10:20 AM
You should be good to go, let me know what happens please.
Jul 27, 2023 at 3:21 PM
