Not charging battery is good
2002 FORD ESCAPE
23,200 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
LKNIGHT
First serpentine belt broke. Mechanic changed power steering pump, tension-er, A/C compressor and belt. Now we have charging problem. Replace burnt belt again and the alternator. Still not charging battery is good. A few months ago had a new radiator fan to go out, mechanic said fuse box under hood had a short. Mechanic does not think this is the problem. Mechanic still does not know why truck not charging had it two days again.
Oct 3, 2018 at 8:13 AM
CJ MEDEVAC
  • 11,004 POSTS
So, this looks pretty simple.
Got you this diagram from "Prodemand" (click on it at the bottom).
I am not seeing a fusible link.
Possible causes:
A bad connection
Skinned or shorted wires
A bad alternator
One of the three fuses may be blown or their legs may be burnt or corroded.
I am going to also include a link to our "repair guides" (easily found at the top right of our pages). Look under "electrical" at alternators.
https://www.2carpros.com/articles
Let us know your findings!
The Medic
Oct 3, 2018 at 4:21 PM
