Changed wheel hub, now no brakes
2005 DODGE DURANGO
180,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
SEMPER942000
Changed the front axles, wheel hub,and brake calipers. After I put all back together and bled the brakes the front brakes will not work. brake pedal goes to the floor. No leaks. is this an ABS issue ? Please help
Jul 12, 2019 at 1:00 AM
SCGRANTURISMO
  • 4,897 POSTS
This sounds to me like you might still have air in the lines, or there is a leak somewhere in the system. Brakes use hydraulic pressure to squeeze the calipers and apply the brakes, so there can be no leaks or air in the system. Here is a link for you to go to below:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jul 12, 2019 at 2:17 PM
