changing transmission fluid?
2012 HYUNDAI TUCSON
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
I have seen several videos some check the level with engine running others with it off, the check level plug is on side of the transmission pan. I would think car should be running but can you please check and let me know, please.
Apr 7, 2025 at 3:06 PM
STEVE W.
  • 15,113 POSTS
The instructions are sort of vague. It says to start the engine, run it through the gears, then lift it and check the level. If oil runs out it's over filled, if none comes out its low. I would say you leave it running for the check.
Apr 7, 2025 at 5:26 PM
BHAMDOC1973
  • 2,008 POSTS
Yes, that's what I am thinking, because when it's off of course there will be fluid and maybe a lot in the pan. Since they didn't state to shut it off, I would assume that.
Apr 7, 2025 at 5:58 PM
STEVE W.
  • 15,113 POSTS
I would say the same.
Apr 8, 2025 at 10:21 AM
