Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Audi
Allroad
Drivetrain
Transmission
Fluid
How to drain and fill transmission fluid?
2015 AUDI ALLROAD
177,000 MILES • 2.0L • TURBO • 4WD • AUTOMATIC
BHAMDOC1973
MEMBER
FOLLOW
How to drain and fill transmission fluid, change filter and gasket if any on this vehicle. please.
Mar 25, 2025 at 12:14 PM
CERTIFIED EXPERT
Yep, there is a filter, but you will need to remove the fluid pan. It looks pretty straight forward.
Here is a guide to help us:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
ZF Lifeguard Fluid 8
Please check the information int he images below.
Mar 27, 2025 at 9:26 AM
BHAMDOC1973
MEMBER
cool, so just drain and fill till it comes out without needing to get it to specific temperature then check again?
Mar 27, 2025 at 11:27 AM
CERTIFIED EXPERT
You need to warm the engine up until the cooling fans come on, then the temperature is correct. Fill until the fluid comes out and install the plug.
Mar 28, 2025 at 9:06 AM
BHAMDOC1973
MEMBER
With engine off.
Mar 28, 2025 at 10:11 AM
CERTIFIED EXPERT
?? the engine must be running.
Mar 28, 2025 at 10:14 AM
BHAMDOC1973
MEMBER
I am asking if engine should be off or running after it gets to temperature and then fill.
Mar 28, 2025 at 10:26 AM
CERTIFIED EXPERT
Running.
Mar 28, 2025 at 12:05 PM
