Sure, here are the instructions on how to change out the transmission fluid, it looks like you will need:
Type .................... Genuine NISSAN Matic S ATF
I would not use anything else but tis fluid.
Capacity* .................... 9-3/4 qt (9.2L)
You will need to have a scanner to check the fluid temperature to make sure it is warm enough to obtain the correct fluid level. Check out the images (below). Let us know how it goes.
Apr 29, 2025 at 11:05 AM
