Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Volvo
XC90
Drivetrain
Transmission
Service
Changing transmission fluid, where is the fill plug located?
2013 VOLVO XC90
136,000 MILES • 3.2L • 6 CYL • 4WD • AUTOMATIC
BHAMDOC1973
MEMBER
FOLLOW
R-design trim. I need to drain and fill the ATF. Can you tell me where the fill plug is? And the type of fluid and capacity recommended for it?
Dec 1, 2023 at 3:31 PM
CERTIFIED EXPERT
If you are adding transmission fluid, you need to remove the air filter box to access the fill port.
I attached directions below for checking the level. The procedure includes adding fluid and what to remove.
Take a look through them and let me know if this helps.
joe
See pics below.
Dec 1, 2023 at 10:57 PM
BHAMDOC1973
MEMBER
What fluid type to use?
Dec 5, 2023 at 1:24 PM
CERTIFIED EXPERT
No problem whatsoever. If you look at the pic below, it includes the fluid type and capacity.
Let me know if this helps.
See pic below.
Image (Click to enlarge)
Dec 5, 2023 at 6:24 PM
