Do I need to use anti-seize compound on the threads when replacing spark plugs
2002 TOYOTA TUNDRA
240,000 MILES • 4.5L • V8 • 2WD • AUTOMATIC
MICHA_S
I am going to change the spark plugs on my truck. The Chilton's recommends anti-seize compound on the threads of the spark plugs. My question is, should I use it and if so should I use copper or aluminum anti-seize compound?
Jul 21, 2018 at 10:42 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
You can use a little bit of the aluminum anti-seize. I would suggest wearing latex gloves and do them all at once because no matter how hard you will try it will get all over your hands. Also, be sure to use a spark plug socket as to not break/damage/crack the new ones when installing. Attached a link for you. Hope this helps and feel free to ask any questions if needed. Thanks for using 2Carpros.
Danny-
https://www.2carpros.com/articles/how-to-change-spark-plugs
Jul 21, 2018 at 11:29 AM
MICHA_S
Thanks Danny. I appreciate the speedy response.
Jul 21, 2018 at 11:50 AM
DANNY L
  • 5,648 POSTS
You are welcome and thanks again for using 2CarPros.
Danny-
Jul 21, 2018 at 1:16 PM
