Easiest way to swap out fuel pump
The vehicle is a 94' G10 4.3 V6
Dec 23, 2015 at 4:44 PM
WRENCHTECH
CERTIFIED EXPERT
There is no shortcut. The fuel tank has to be removed
Dec 23, 2015 at 5:00 PM
BOBZILLA147
MEMBER
Thanks man i was thinking about cutting floor pan to save time its a 700$ work POS to avoid bustin straps
Dec 23, 2015 at 5:12 PM
WRENCHTECH
CERTIFIED EXPERT
That's a bad idea. The is a space between the floor and the pump and the pump usually doesn't come straight out so you would need a considerably larger hole, even if you did know the exact spot and you don't. Bad idea all around.
Dec 23, 2015 at 5:15 PM
BOBZILLA147
MEMBER
Yea it was just a thought again thanks man
T
The tanks coming out then
Merry Christmas to you and yours
