Hello, I have done extensive font end work. Or by the time I'm done I will have. I've asked a lot of questions and always gotten excellent advice/ answers. My question is, when changing the front struts what is the proper procedure? I do not have a lift/rack. What I'm wanting to know is front of the ground? And which end of the strut should be removed first? Do I loosen the three nuts under the hood per strut then move to the bottom of the strut? By the way I'm replacing the struts as a whole unit. The struts come with an elliptical/oval top hole for camber adjustment. So, it will save me work from having to modify the holes. I've never changed struts and I'm aware they can be dangerous if you don't know what you're doing. Thanks as always. JC
Jun 8, 2023 at 9:08 PM
