I’ve got a rebuilt engine I’m putting in the truck. I’m taking out the stage 4 cam that was in there and putting back a stock cam. I’ve got the 2 dots lined up on cam and crank sprocket also the number 1 piston it’s all the way up, so I assume I’m at top dead center. The problem I’m having is when I torque the 3 bolts for cam sprocket to 26-foot pounds according to Hanes manual then I try and turn crank it won’t turn I've even torqued it lower to 15-foot pounds and it will not turn. I hand tighten and I can spin it easy. What’s going on maybe wrong sprocket.
Sep 5, 2022 at 10:24 AM
