Check Engine and AT light came on. Pulled code P0771. Due to age and mileage, I decided to change the entire Shift Solenoid Block. Drained, dropped pan, removed block, installed new one, ensured all connectors were in proper spot. Refilled, reconnected battery and the car started. However, it would not shift into any gear. Once I turned the car off it would then not restart. It was if the car thought it was still in a gear so it wouldn't even attempt to crank.
One note, the two valve springs and casing in the image both popped out. I wasn't certain which one went in each slot. They looked identical but I noticed the part number in the image is different for each spring.
Would this have caused the issue I'm facing?
Oct 19, 2024 at 8:11 AM
