changed radiator, now truck wont start
1999 CHEVROLET SUBURBAN
150,000 MILES • V8 • 4WD • AUTOMATIC
TINAMARIEPARRACK
changed the radiator, now the truck turns over, but will not start. Was advised to check spark plugs for liquid. Thought it might have been a head gasket. Plugs are dry. fuses are good. don't know what else to do please help!!!
Jan 14, 2014 at 4:24 PM
Are you getting spark to the plugs and fuel to the fuel rail?
Jan 15, 2014 at 5:28 AM
TINAMARIEPARRACK
I believe there was spark to the plugs. My boyfriend took the plugs out and sand papered them to clean them up. I am not sure about the fuel to the rail. How do you check for that?
Jan 15, 2014 at 10:41 AM
TINAMARIEPARRACK
also was told that if there was an air bubble in the radiator when it was changed that this would prevent the truck from starting. Is this true?
Jan 15, 2014 at 10:42 AM
Here is a video for checking fuel pump pressure. Also, make sure the spark to the plugs is a hot blue snapping spark.
https://www.2carpros.com/articles/checking-fuel-pressure-regulator
Jan 16, 2014 at 5:32 AM
