Hi and thanks for using 2CarPros.com. There is a relearn procedure. The following information is specific to your vehicle.
CONVERSION CALCULATOR
1999 GMC Truck S15/T15 Jimmy 4WD V6-4.3L VIN W
Vehicle » Powertrain Management » Computers and Control Systems » Crankshaft Position Sensor » Testing and Inspection
TESTING AND INSPECTION
Install the scan tool.
Apply the vehicle's parking brake.
Block the drive wheels.
Close the hood.
Place the vehicle's transmission in Park (AT) or Neutral (MT) .
Idle the engine until the coolant temperature reaches 65°C (150°F) .
Turn OFF all the accessories.
IMPORTANT : If the CKP System Variation Learn Procedure cannot be completed successfully, refer to DTC P1336 Crankshaft Position (CKP) System Variation Not Learned for additional diagnostic information.
Enable the Crankshaft Position System Variation Learn Procedure with the scan tool.
IMPORTANT : After the ignition switch is turned to the CRANK position, the VCM must see a change in the state of brake switch (Released to Applied) to run the learn procedure. Also, the service brakes, not the parking brake, must be held throughout the duration of the learn procedure.
Apply and hold the service brakes.
IMPORTANT : While the learn procedure is in progress, release the throttle immediately when the engine starts to decelerate. The engine control is returned to the operator and the engine will respond to throttle position after the learn procedure is complete.
Slowly raise the engine speed to 4000 RPM .
Immediately release the Throttle when the engine speed decreases.
Turn OFF the ignition for 15 seconds after the learn procedure is completed successfully.
JUST FOR INFORMATION, here are the specific directions for replacing the crank sensor so you can make sure everything was done correctly.
Vehicle » Powertrain Management » Computers and Control Systems » Crankshaft Position Sensor » Service and Repair
SERVICE AND REPAIR
REMOVAL PROCEDURE
CAUTION: Refer to Battery Disconnect Caution in Service Precautions.
IMPORTANT : The CKP System Variation Learn Procedure will need to be performed whenever the Crankshaft Position (CKP) sensor is removed or replaced. Refer to CKP System Variation Learn Procedure .
Disconnect the negative battery cable.
Raise the Vehicle.
If the vehicle is equipped with the underbody shield package, then remove the steering linkage shield mounting bolts.
Remove the steering linkage shield.
Disconnect the CKP sensor harness connector.
Remove the CKP sensor mounting bolt.
Remove the CKP sensor.
INSTALLATION PROCEDURE
IMPORTANT :
When installing the CKP sensor, make sure the sensor is fully seated before tightening the mounting bolt. A poorly seated CKP sensor may perform erratically; possibly setting false DTCs.
Do not reuse the original O-ring.
Replace the CKP sensor O-ring.
Lubricate the O-ring with clean engine oil before installing the CKP sensor.
IMPORTANT : Make sure the CKP sensor mounting surface is clean and free of burrs.
Install the CKP sensor.
NOTE: Refer to Fastener Notice in Service Precautions.
Install the CKP sensor mounting bolt.
Tighten
Tighten the CKP sensor mounting bolt to 20 N.m (15 lb ft) .
Connect the CKP sensor harness connector.
Install the steering linkage shield.
Install the steering linkage shield mounting bolts.
Tighten
Tighten the bolts to 33 N.m (24 lb ft) .
Lower the Vehicle.
Connect the negative battery cable.
Perform the CKP System Variation Learn Procedure. See: Testing and Inspection.
Let me know if this helps.
May 27, 2018 at 8:17 PM
