Changed fuel filter warning light stays on
2017 TOYOTA PICKUP
40,000 MILES • 2.4L • 4 CYL • TURBO • 2WD • AUTOMATIC
ELMORVAGZ
  • 4 POSTS
There was a warning in panel to change diesel fuel filter and we did it with new filter. During replacement we did not disconnect battery.
My problem is: the warning in panel is still there not disappear.
What shall we do to erase the warning light in panel.
Awaiting for your kind answer.
Thank you.
Elmor Vagilidad
Apr 21, 2020 at 7:00 PM
Try this: Turn the key to the off position. Open the hood and disconnect the electrical connector to the filter housing. Start the engine, and then reconnect the connector. That should reset it.
Let me know if that helps.
Apr 21, 2020 at 7:25 PM
ELMORVAGZ
  • 4 POSTS
Hello Joe,
Good day to you!
I am very thankful because of the help you have given me.
Simply, it works.
I followed exactly the instructions according to your email: With engine switch off, disconnect the electrical connection to the fuel filter then, start the engine and reconnect again the wires to the filter and yes the warning was gone, cleared.
Thank you very very much.
Elmor Vagilidad
Apr 22, 2020 at 12:36 AM
You are very welcome. Let us know if you have questions in the future or need help with anything.
Apr 22, 2020 at 9:10 AM
