Change crankshaft main bearing caps torque specs needed?
2007 FORD F-150
120,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
DUSTIN07F150
Hi, I just watched the videos on YouTube about “how to build a Ford 5.4 3V Engine” and these are really nice and helpful videos.
I got a question regarding the torque specs on the bolts which tighten and fix the main bearings. In the videos you used new studs and with nuts from ARP and also you explained the torque specs needed for them (20,40,60ft). I am just going to use brand new original Ford bolts (F6AZ-6345-AA) for this job. So, can I use the same torque specs for the bolts as for the ARP studs 20,40 and finally 60ft?
Or should I use the torque specs 32ft and finally another 90degrees as you used in the video to measure the squish between crankshaft and main bearing?
I am looking forward your feedback and thanks for helping
Best regards, Dustin
Sep 29, 2024 at 4:28 AM
Hi Dustin,
We are glad you like the video series. If you are using the stock ford bolts use the stock torque specs from Ford.
Main Bearing Cap Torque & Sequence
Vertical main bearing cap fasteners
Step 1 .................... 40 Nm (30 ft. lbs.)
Step 2 .................... additional 90 degrees
Let us know if you need anything else.
Sep 29, 2024 at 10:36 AM
