chain cover reseal
2007 TOYOTA COROLLA
180,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
LASTMOH
  • 26 POSTS
can you please give instructions how to reseal chain cover for engine 1ZZFE and what kind a sealer i need to use?
May 9, 2020 at 2:08 PM
I attached the process to reseal the cover and it includes the sealing pack needed. Let me know if you have more questions. Thanks
May 9, 2020 at 6:39 PM
LASTMOH
  • 26 POSTS
so there is no gasket . i need to use silicone right?
May 11, 2020 at 2:24 PM
That is correct. There is seal for this one. It is a continuous bead of silicone. Don't worry if you get a skip in it. Just go back and fill in any points you missed. They say continuous but it doesn't need to be done in a continuous manner. It just needs to be a continuous bead when you are going to install it. Let me know if that doesn't make sense. Thanks
May 11, 2020 at 7:49 PM
LASTMOH
  • 26 POSTS
is there an alternative to the silicone i can use? that is antifreeze and oil resistant.
May 12, 2020 at 6:08 PM
You need an RTV. Permatex says theirs works but I have not used it on a timing cover. I have not had luck with the gray Permatex but the black may hold up. If it were me, I would give it a try because I would not pay the $40.00 for the single tube of 3 bond from Toyota.
May 12, 2020 at 6:56 PM
