Here are the directions for removal and install of the two part drive shaft and the center support bearing. All attached pics correlate with the directions.
___________________________
2001 Chevy Truck C 1500 Truck 2WD V6-4.3L VIN W
Two Piece
Vehicle Transmission and Drivetrain Drive/Propeller Shafts, Bearings and Joints Drive/Propeller Shaft Service and Repair Procedures Two Piece
TWO PIECE
Propeller Shaft Replacement - Two Piece
^ Tools Required
- J 43218 Clamp Plier
Removal Procedure
Important: Observe and accurately reference mark all driveline components relative to the propeller shaft and axles before disassembly. These components include the propeller shafts, the drive axles, the pinion flanges, the output shafts, etc. All components must be reassembled in the exact relationship to each other as they were when removed. In addition, published specifications and torque values, as well as any measurements made prior to disassembly must be followed.
pic 1
1. Raise the vehicle. Refer to Vehicle Lifting.
2. Reference mark the rear propeller shaft (3) to the rear axle pinion yoke (4).
3. Reference mark the front propeller shaft to the transmission or transfer case (slip yoke type) or to the transmission pinion yoke (universal joint type).
pic 2
4. Remove the clamp (2) securing the boot (3) to the front propeller shaft stub shaft (4) and the rear propeller shaft slip yoke (1) by prying up the exposed end of the clamp (2) using a flat bladed tool (if applicable).
pic 3
5. Remove the bolts (1) and the yoke retainers (2) from the rear axle pinion yoke (4).
Notice: When removing the propeller shaft, do not attempt to remove the shaft by pounding on the yoke ears or using a tool between the yoke and the universal joint. If the propeller shaft is removed by using such means, the injection joints may fracture and lead to premature failure of the joint.
6. Slide the rear propeller shaft forward in order to remove the propeller shaft from the rear axle pinion yoke.
7. Slide the rear propeller shaft rearward in order to disconnect the rear propeller shaft from the front propeller shaft stub shaft.
8. Remove the rear propeller shaft from the vehicle.
9. Remove the boot from the front propeller shaft stub shaft (if applicable).
pic 4
10. Remove the center bearing support nuts (1).
11. Remove the center bearing support (2).
pic 5
12. Remove the front propeller shaft by sliding the front propeller shaft rearward from the transmission or the transfer case (w/o RPO MW3 or M74).
pic 6
13. Remove the bolts and the yoke retainers from the transmission pinion yoke (w/ RPO MW3 or M74).
14. Remove the front propeller shaft by disconnecting the front propeller shaft from the transmission pinion yoke (w/ RPO MW3 or M74).
Installation Procedure
pic 7
1. Install the front propeller shaft by sliding the front propeller shaft into the transmission or the transfer case (w/o RPO MW3 or M74).
pic 8
2. Install the front propeller shaft to the transmission pinion yoke (w/ RPO MW3 or M74).
Important:
^ Align the reference marks made during removal.
^ Tighten the bolts until snug. Do not torque the bolts at this time.
3. Install the yoke retainers and the bolts (w/ RPO MW3 or M74).
pic 9
4. Install the center bearing support (2).
Notice: Refer to Fastener Notice in Service Precautions.
pic 10
5. Install the center bearing support nuts.
^ Tighten the bearing support nuts to 40 Nm (30 ft. lbs.).
6. Tighten the yoke retainer bolts (w/ RPO MW3 or M74).
^ Tighten the yoke retainer bolts to 25 Nm (19 ft. lbs.).
7. Inspect the splines of the front propeller shaft stub shaft for a sufficient coating of grease. If the splines of the stub shaft does not have a sufficient coating of grease, lubricate the shaft with chassis grease (GM P/N 12377985 or equivalent).
8. Install the boot (3) and two new clamps (2) onto the front propeller shaft stub shaft (4) (if applicable).
9. Install the rear propeller shaft slip yoke onto the front propeller shaft stub shaft.
Mate the missing tooth in the yoke with the bridged tooth on the splined shaft.
10. Install the rear propeller shaft onto the rear axle pinion yoke. Align the reference marks made during removal.
pic 11
11. Install the yoke retainers (2) and the bolts (1).
pic 12
12. Using the J 43218, crimp the boot clamps until the dimensions shown are obtained.
13. Lower the vehicle.
_____________________________
Oct 16, 2020 at 6:05 PM
(Merged)
