Center console control panel not working
2012 INFINITI M37
75,000 MILES • 2.5L • V6 • 2WD • AUTOMATIC
SPEEDFREAK328
Hi, I have the car listed above, a Japanese import version of Nissan Fuga. I think it's similar to m37 just the engine is 2.5. last Sunday I made a replacement on the LCD screen due to not working. After installed, I put back the radio and center control panel back in place. Everything was connected all the back wires are tightened. At first I replace the fuse located close to the battery compartment then it worked. Center control was working and able to control all the A/C fan. But then after I screw everything on the radio and fit the underside panel, then the center console came dead again and not working. No light on the panel. I checked again the fuse but it was not blown. Every fuse I checked on the battery compartment, and on the side of the pedal accelerator, all came in good. Is there any other fuse box I have not found or any other problem that the console won't turn on. Now Every time I start the engine, the A/C and blower fan will run full throttle. Without the center console working, I cannot control the fan and I have to go to work with full swing on the fan. Please help me to diagnose the problem. Really appreciate your help. Thank you
Jan 21, 2020 at 11:12 PM
I'm not sure which vehicle you have. Can you tell me if you removed the panel again and checked to make sure nothing was disconnected, damaged, pinched or anything? If it was working prior to underside panel install, something is most likely a problem there.
Let me know. Also, if you could take a pic of the console so I have a better issue of what you are working on, it may help.
Jan 22, 2020 at 6:17 PM
