Check engine light will it flash one single time when you initially turn ignition key on
1998 MERCURY MOUNTAINEER
330,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
DOUGLAS CHEEK
When all codes are eliminated check engine light stays off while running will it flash one single time when you initially turn ignition key on.
Jul 20, 2019 at 4:21 AM
BMDOUBLE
  • 1,139 POSTS
Yes that is normal, if I understand you correctly. Get in, start the vehicle, cel light initially comes on then turns off, normal operation, it is a prove out for the warning lamp.
Jul 20, 2019 at 7:29 AM
