We often need to know the engine size to get the right wiring diagrams and parts lists, but not in this case.
Oh; that adds another dimension to this sad story. I used to tell my students it was not proper to run a new wire to solve a problem. The defect in the old wire must be found because whatever happened to it is likely to happen to the others in that harness. Common things are a harness fell down and was rubbing on the sharp edge of a metal bracket, it fell onto hot exhaust parts, or a screw got run through that harness. How long will it be before the same thing happens to the next wires in that harness, and where will your customer be on a dark Saturday night when he's broke down on the side of the road?
In this case we can assume the defect was caused by operator error, and while a hot wire will melt the insulation on adjacent wires, we are probably safe in assuming if no other damage has shown up in those other wires this far, they will likely be okay. This would be an appropriate time to run a new power wire for your radio.
The light green/yellow wire is for the radio's memory circuit so it is always live. My question is if the yellow/black switched power wire got red hot, why did the fuse not blow? That is just a 15-amp fuse. 15 amps will not turn that wire red hot.
Nov 27, 2020 at 4:57 PM
(Merged)
