Cause of misfire in my engine
2006 GMC ENVOY
160,000 MILES • 1.3L • V8 • 4WD • AUTOMATIC
MAGGIE HILES
A week after i purchased my 2006 GMC Envoy Denali, we finally did highway driving. half way to Cindy had issues that we found was cylinder six misfire. Car lot fixed problem. Got it back and timing was off, gave it back, they said they turned and timed it. Clearly it was fixed, but no proof of tuneup, no nee plugs or wires.
About three months ago i noticed a slight lag. I procrastinated. Took it back to car lot and now cylinder seven misfiring and pretty much dead, or 100% dead. They told me to drive it because it would not break down anytime soon. They told me they could get a warranty on my truck at any time and that a $215.00 deductible, paid by me, would cover new engine and transmission. They told me to wait until after the first so it is financially easier on me, rather than right before Christmas. So that leads me to believe the cylinder was not totally dead. But they did not unhook fuel injector from that cylinder. They did not warn me of the fire hazards with the catalytic converter. So what caused it?
Right now, we think the head gasket is gone or almost gone, white smoke sometimes bellows out exhaust, but also, sometimes does not smoke at all. Happens at different times too. Sometimes when i start vehicle, sometimes when i accelerate hard, and sometimes when i am idling on a hill. We smell burnt oil and we have to fill coolant every few days. Noticeable decline of power since the smoke started. It also has a shake/stutter when idling.
What is causing these misfires?
1) Loss of spark (worn, fouled or damaged plug wires, or cracked distributor)?
2) Air fuel mixture out of balance (not timed)?
3) Loss of compression?
So if they tuned it up after the first cylinder issue, could root cause be plugs and plug wires?
Did they just time it and not do a tuneup?
Or did they not even time it? And that would cause the air fuel mixture to be unbalanced.
Jan 3, 2019 at 3:23 AM
This is a tough one since I cannot see it or touch it.As far as the dead cylinder, all they had to do was a leak down test and they could have told you the exact reason for no compression.Do you have receipts from the repairs you could upload for me to see There are times that we do timing chains and do not do plugs. we replace only when needed. that is a call on the shop.
As far as you driving, bad idea. that miss caused far more damage to the motor. the fact the catalytic converter overheated means that has to be replaced and that will not be warranty. that will be on you.
It sounds like you might need a tune up or have a bad spark plug-coil (common), injector or low compression to be sure which one it is please follow these videos and guides.
https://youtu.be/QTE8k06MzwQ
and
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
and
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
This whole deal sounds fishy. did you not get the warranty when you bought it? if not, the warranty company will be asking many questions as to why this happened so close to you taking out the warranty.
Jan 3, 2019 at 4:52 AM
