I'm not sure which engine you have. If it is the 4 cyl, there will be one which is part of the exhaust manifold. See pic 1 There will also be one located down from there in the exhaust system.
___________________
If you have the V6, there will be one on each of the exhaust manifolds and one after them lower in the system. See pic 2.
___________________
If you look at pic 3, it shows the downstream catalytic converter in the exhaust system.
So, if you have a 4 cyl, you have two. If you have the 6 cylinder, you have 3.
__________________
Jan 28, 2021 at 5:26 PM
