I recently blew a head gasket. Replaced the engine but apparently ran a lot of coolant/water through the system and by extension the catalytic converters. The mechanic who did the motor swap indicated the check engine light was because of bad catalytic converters. He indicated all would need to be replaced. I know unburnt fuel can cause cat failure. Would coolant/water have the same effect?
Aug 3, 2019 at 9:17 AM
