loss acceleration power possible clogged catalytic converter
2005 CHEVROLET ASTRO
215,000 MILES
MIGHTY777
Car loss acceleration power. Last time I drove the car it would not accelerate above twenty mph and the engine cut off and would not start until it cooled down. Car turns off when engine gets warm. I smell what smells like burning plastic from underneath the steering wheel. I have multiple codes, o2 sensor, 2 and third gear shift solenoid, crank and camshaft position sensors. I did change the crankshaft position sensor and there was a dent on the sensor I removed. I believe the loss of power may be due to a clogged converter. Any help in diagnosing the issue will be greatly appreciated. Thank you
Jan 1, 2017 at 5:15 PM
JOHNNY G.JR
  • 320 POSTS
Cover tailpipe with a wet cloth to see if engine stalls out.
Jan 1, 2017 at 8:12 PM
MIGHTY777
Okay, I am going to give that a try tomorrow because I have to Jump start it. I think the battery has gone out on me. The car has been sitting for about five months.
Jan 1, 2017 at 9:14 PM
MIGHTY777
I had to jump start it the other day and when it turned off it would not turn back on.
Jan 1, 2017 at 9:15 PM
JOHNNY G.JR
  • 320 POSTS
Charge battery slowly overnight,clean,wire brush all connections and reinstall battery.
Jan 1, 2017 at 10:19 PM
JOHNNY G.JR
  • 320 POSTS
You mentioned plastic burning, possible short circuit in wiring harness inside of steering column.
Jan 1, 2017 at 10:23 PM
MHPAUTOS
  • 31,937 POSTS
I would start with dropping the column covers and inspecting for any shorts in the ignition harness.
Jan 2, 2017 at 2:36 AM
