Shuts off while driving
2009 KIA RIO
116,859 MILES • 2WD • AUTOMATIC
LINDA HURST
It tries to shut off or cut out going down the road. It will shut off three or four times before I get it going. The colder the weather the worse it is. Could this be the catalytic converter?
Sep 19, 2018 at 8:49 PM
First, confirm that the fuel pressure is within the manufacturer's specs. Here are general directions for checking:
Here is a link that discusses catalytic converter issues:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Here is a link that shows how to check the converter:
Next, I have attached three pictures which are the directions specific to checking fuel pressure on your vehicle. Keep in mind, this could be something as simple as a partially plugged fuel filter. Here are the manufacturer's specs for pressure.
Fuel pressure test
Standard value .................... 343 kpa (3.5 kg/sq.cm, 49.8 psi)
Check these things and let me know what you find. I hope this helps.
Sep 20, 2018 at 5:58 PM
