Catalytic converter
2005 HONDA ELEMENT
160,000 MILES • 4WD • AUTOMATIC
CVRODRIGUEZ
Greetings! Do you know how many catalytic converters are in the vehicle listed above?
Nov 26, 2019 at 4:05 AM
SCGRANTURISMO
  • 4,897 POSTS
There should just one catalytic converter on your vehicle. Here are a couple of links below explaining how to test and replace your vehicle's catalytic converters below:
https://www.2carpros.com/articles/catalytic-converter-replacement
Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Nov 26, 2019 at 7:07 AM
CVRODRIGUEZ
Thank you for such a fast and thorough response! I had my catalytic converter replaced last February and the check engine light came on with a code that the cat was having issues again. The garage I went to said it could be a different catalytic converter in my vehicle, other than the one they replaced. I didn't think it had more than one. I appreciate it!
Nov 27, 2019 at 5:39 AM
JIS001
  • 3,412 POSTS
Hi, just wanted to jump in real quick. There was a bulletin for a software update to correct the P0420. Here is the bulletin. Chances are the original catalytic converter may have been okay.
2005 Honda Truck Element 4WD
L4-2.4L
Engine Controls - MIL ON/DTC P0420 Stored
Vehicle Powertrain Management Technical Service Bulletins Engine Controls - MIL ON/DTC P0420 Stored
ENGINE CONTROLS - MIL ON/DTC P0420 STORED
08-002
October 11, 2011
Applies To:
2005-06 Element - All Models With M/T
2005-06 Element: MIL Comes On With DTC P0420
(Supersedes 08-002, dated July 21, 2011, to revise the information marked by asterisks and black bars.)
REVISION SUMMARY
* Under WARRANTY CLAIM INFORMATION, the flat rate time was changed.*
SYMPTOM
The MIL is on, and DTC P0420 (catalyst system efficiency below threshold) is stored.
PROBABLE CAUSE
The ECM software misinterprets sensor inputs as a deteriorated catalytic converter.
CORRECTIVE ACTION
Update the ECM software, and check the three-way catalytic converter.
Nov 30, 2019 at 12:01 AM
