The vehicle was running fine but after a short period of inactivity, now it won't start. The engine cranks over and I can smell fuel, the fuel pressure is 55 PSI. I can't check for spark by myself (help) and I cleared an O2 sensor code indicating a rich mixer. I replaced all of my ignition system components except spark plugs but all eight plugs don't normally fail at once so I don't think the spark plugs are a concern. When cranking, the engine never fires or starts and shuts off (security key) although it has done this in the past. Now it just cranks and the split second I let go of the key it coughs like a light backfires through the throttle body. I normally do my own maintenance because I'm a certified aircraft mechanic but before I start replacing catalytic converts and exhaust systems, I would like some feedback.
Apr 14, 2021 at 2:56 PM
