There is a lot of play/flex on the driveshaft in the center support/bearing
2015 GMC TERRAIN
80,000 MILES • 4 CYL • 4WD • AUTOMATIC
FIREBIRDCF
Little over 1/4 inch of movement. Also having slight vibration at speed. Do you have the part number for just the center support/carrier bearing? All I have found online is the whole driveshaft kit that is over $300.00.
Jan 18, 2021 at 4:27 AM
Good morning,
There is no part number for the center support as it is part of the driveshaft. It is not like the older versions where it is serviced separately.
I attached the driveshaft available from Rock Auto for you and the procedure for replacement.
Jan 18, 2021 at 5:59 AM
